Blowing fuse
xjon
Car: 99XJ, 93 240coupe
My whole interior lights are out including my radio. Checked the fuses and found the one. It is located at the drivers kick panel labeled "room lamp 10amp".
The problem is that if I replace the fuse, it just pops instantly. What is the problem?
More info. This started when I took a high speed turn, sweeping right and I had a stroller in the trunk. I heard a loud thunk. All my plastic panels are gone. What could the stroller have hit or broken to cause this problem inside the car?
TIA
bcar240
Car: 1993 240SX HB
If you mean the stroller was swept to the passenger side of the car, it is possible it hit and broke the trunk light that is in the back right corner of the trunk. It might have caused a short there that would blow the fuse.p.s. this is for S13s. S14 might be different.
