Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Jan 04, 2008 2:19 pm
The ATCU is interchangable with any other ATCU from the same generation. IE you can slap any S13 ATCU in and be fine, but you can't put an S14 ATCU into an S13 chassis IIRC.
And remember that there is no transmission control unit for manuals. In case that's what you meant.
Lastly, I know this may sound a bit nitpicky, but calling it a TCU is confusing. Everyone will think you're talking about the Timing Control Unit as the first response in this thread did. If you call it by its proper acronym, you'll make everyone's heads hurt a little less.
