Blower relay Location
kfk256
Hello all,
Can someone please tell me where the blower relay is located (pictures will help) in a 2006 m35x. I looked at the panel next to the foot parking brake, but i only see fuses not any relay. Thanks.
ae7456t
Car: 2006 M35X with 19X,XXX miles
I just went through this exact issue. My heater would take 15-20 minutes to start blowing and replacing the relay did the trick.
The relay is on the back of that fuse block. The block is help in place by 4 plastic tabs...Once those are released, the replacement of the relay is a snap.
Here is a quick listing for the fuse block that helps you visualize where they are (not my listing, just informational).
http://www.ebay.com/itm/06-10-infiniti- ... 2c8a4df164
kfk256
Thank you ae7456t. I was able to locate and replace it , and just like you said.......It's fixed now. A big headache fixed for less than $80. Awesome! :dblthumb:
NOLAHEAT
Car: 2006 M35
I've been trying to get the fuse block out and can't seem to depress those four tabs correctly. Do you just stick a flathead in there and sort of pry them upwards? Do the tabs on each side do anything?
