Blower motor
Bktimby
Car: 2009 Nissan Rogue
Good afternoon
I searched until I’m blue in the face. So I’m making a post.
I have a 2009 Rogue
Daughter was driving it and heard a pop and blower quit working.
Changed blower motor, blower resistor, and the blower/A/C controls.
Still no blowing
I seen on here in my wide search and downloaded the HAC book on this. Went thru all the troubleshooting checks.
Still I can’t find anything wrong.
Bench tested the blower it’s good
There is something that is strange to me is the blower plug yellow wire is battery hot when I put multimeter on the red wire it has 11.70 volts on it. I’m now confused when there is 2 hots going to the fan motor.
Any help would be appreciated
Rockhoundrob
Car: 2009 Nissan Rogue SL
There should be 1 hot wire and 1 ground.
Are you saying it is hot all the time, or only hot when your turn on the fan?
I attached a diagram. Your problem is in the red zone.
1) Check fuse 15 and fuse 16.
2) Check blower relay
3) check Fan Control Amp.
If all of these are good, you will need to unplug all the wires and figure out where the "Hot" source is coming from, that shouldn't be there.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
If she heard an audible noise then chances are either the relay went bad or both fuses blew (there are two of them in parallel, as you can see in Rob's diagram). You can also see that the relay is north of the fuses, so if the fuses have power with the key on, then the relay is good and you don't need to get at it to check. You can find the factory wiring diagram here on HAC-57:
https://www.nicoclub.com/service-manual ... %2FHAC.pdf
Bktimby
I will recheck everything this weekend when she gets home.
Return to “Rogue Forum”
