Blower motor
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
blower motor just quit working one day.
I've been working on diagnosing the problem but I'm stuck. Blower does not operate at any speed. Not getting any power to Blower motor connector.
I assume its not the resistor because it doesn't work at any speed.
If I jumper the fan with +12 it spins.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Fuse?
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
nope, checked both of those.
IT's a 93 hardbody BTW
Rev_D21
Sounds like broken wire somewhere.
RT22
Car: 1991 nissan hardbody
getting power to the switch? maybe the switch is opened? Start at motor and trace back until you find 12 volts, that is only way to find where it is being lost
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
Just in case anyone had a problem like this in the future.
Check for power going to the Blue wire at the blower motor harness. No power there indicates a short between the fuse panel and blower motor.
My problem was a loose wire at the back of the Fuse panel.
Thanks for every ones input.
RT22
Glad you found the problem. Old electronics teacher taught me the best way to find electrical stuff, divide and conquer. Start in middle of the circuit if it is good signal to that point half the system is eliminated, keep doing that until you find where signal is lost. fastest way to hunt down electrical problems, keep splitting the system in half.
