Blower motor stopped working
Dougmorr
Car: 2008 Nissan Rogue
My blower motor stopped working. Fuses and relays are good. I read that the blower motor resistor could be the problem. Anyone have similar issue?
Lone Wolff
Car: 2015 Nissan Rogue SL AWD
2025 Toyota Corolla Hybrid
2010 Ford F150 Lariat 4x4 5.4L
2010 Ford Fusion SEL
1968 Firebird 400
Had it happen in a different vehicle, but not my Nissan. It was an easy fix in my truck as it was located behind the glove box. Plenty of room to access everything and nothing to remove/disassemble.
Good luck.
Rogue Jarhead
Car: 2011 Nissan Rogue Krom
Check out the fsm. It should give you an idea of where it is located and how to remove and replace it
Return to “Rogue Forum”
