Blower Motor Resistor
A forum for the Nissan Quest... minivan lovers unite!
Mrsteve125
Car: Nissan Quest
Does anyone know where to find the blower motor resistor on a 2008 Nissan Quest Base model? Fan speed settings not working.
macgiver
mac ,I believe the speed variation (if "infinitely variable" ) is derived via a "finned" (heat-sink) POWER TRANSISTOR , and if you are failing to do a "Lookup" locating a RESISTOR is why you can't find it . By the way a big POWER RESISTOR may be in the ckt. - but they are simple , "Bullet proof" (compared to the transistor) and DO NOT themselves change the speed of your fan. Old school - incrementally / "stepped" speed(s) used to use a "multi-tapped bridge" resistor , and the highest speed was simply full B+ voltage to the fan .:gapteeth: Locating that Finned transistor in FSM , or "Google" images may point location out ! :yesnod GT
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
far raf
Car: 2005 Nissan Quest SE (standard? simple? edition - i.e. nothing special)
+1 for burnt transistor being most likely root cause. This is a famous thing on Honda forums and we figured a replacement part. If I remember correctly any high current PIC* series would work.
Return to “Quest Forum”
