qship96 »
https://forums.nicoclub.com/qship96-u3104.html
Sat Jan 28, 2006 8:21 am
replaced the blower motor today,as it is almost 60 degrees here in Baltimore today! total job took 45 minutes-6 bolts and the entire glove box and lower panel comes out,then 3 bolts on the motor itself- very easy on the 94-96Q. took the time to remove darlington assembly and evaporator looked pretty clean after 170,000 miles-must be due to lots of compressor run time over the years allowing the condensation to flush the evaporator of debris.Took the old motor apart,and the only problem I could detect was the brushes were at their wear limits-probobly could have had them replaced for 20$ by a electric motor repairshop and saved even more.
