Blower motor relay??
mikejo18
Car: 2001 Nissan Xterra
I recently purchased a 2001 Xterra and have a few problems. My ac/heat blower will work only when it is turned all the way up. If I attempt to take the setting down from anything other than max it shuts off. I have asked around and most have no idea other than perhaps a blower motor relay? Any idea how this is replaced. Also I have a prob with the temp. on the rear view mirror. It constantly reads 140*F, can this be fixed or just replaced?
Thanks for any help.
Big-Bird
Car: 2000 Xterra on 'Roids & 2004 Quest SL
Check your email for the Entire Xterra electrical system in PDF format. Read through this section and it should answer all your concerns.
mikejo18
Thanks for the help!
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
Wade Rocks!
-Dan
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
The resistor is bad on the blower motor - common problem, and about a $30 fix from your local nissan dealer for the part.
You'll find it down around the kick panel on the passenger side. Unbolt, unplug, and reverse for the install.
NM50
Car: 94 D21,98 03 hummer H2,66 311 CA18ET ROADSTER,94GEO METRO pimp mobile
VERY TRUE RAT.THE BLOWER RESISTOR IS THE CULPRIT.LOCATED IN THE DUCT BETWEEN THE MOTOR AND CORES.
Big-Bird
I did suspect that the resistor would be the most lilkely culprit...but the file I sent out is small enough I figured he might as well have it in the event the resistor wasn't at fault.
