Newbie to the NICO site.
I'm hoping someone can point me in the right direction with a blower motor issue on my 2006 350Z. Everything worked perfectly and then the fan just stopped coming on whether it's on a/c or heat. Fan speed knob also has no effect.
The first thing I did was swap out both 15 amp fuses marked "blower" in the fuse box by the driver's side dead pedal even though both looked fine. After that didn't work, I figured it must be the blower motor itself, so I bought a new one and switched it out. NOTHING.
I understand that there may (or may not) be a "blower motor relay" located behind the fuse panel by the driver's side dead pedal. I ran out of time last night, but I did pull the plastic shroud off to expose the entire fuse panel. It appears that there are 3-4 bolts holding it in place and it looks like I will need to remove the dead pedal to get to 1-2 of them.
Has anybody had similar issues and what was the fix?
Thanks for the feedback!...............Joel
