Bypassing the resistor actually goes to HIGHER than full speed. Or, at least, that's what happened when my Q's went bad. It was nonsense high speed. Hurricane setting. Way higher than max speed via the climate control. Obnoxiously loud. And the rest of the car was already noisy as Hell, so the fact that it was noticeable is quite a feat.Dattebayo wrote:You could easily bypass the resistor if you knew what you were doing, but all you would get is just the highest setting. That's kinda useless. Also, if you say that the highest setting is not working right now at all, then it's most likely not the resistor and is the motor switch on the dash.
