Gm's suffer from that with K&N filters... FYIfloat_6969 wrote:Do it and make a write up! My only concern with a blow through setup is if you're getting oil in the intake stream via the PCV system or failing oil seals, it might gum up the MAFS.
I disagree, you will still get reversion with the setup as illustrated, infact i think it will overfuel worse than with a conventional MAF setup and a BOV on the cold side, it MAY work if you have the MAF right infront of the throttle bodyjt15833 wrote:yes so long as the MAF is after the BOV. His BOV is on the hotpipe and MAF will be on the cold pipe.
i bow to your real life experience then. Its never going to be an issue for me, I will never run an atmospheric dump valve, or probably any dump valve of any sortBwana wrote:
Not so.
I run a blow through setup on my RB car with a gt3076r and a hks ssqv mounted on the hot pipe with the MAF located just after the fmic. Drivability is flawless, absolutely 0 evidence of overfueling during shifts or any other time for that matter.
