Blow Thru-MAF questions?
turblu
Where is the best place on the charge piping to mount the MAF? On the Hot Side or the Cold Side? Also what are the benefits of going with a blow-thru-MAF setup other than not having to recirculate the BOV?
turblu
bump for help..
S13FASTBACKSR
Car: '92 Fastback SR powered
its most commonly mounted on the hotside..you'd have to find somebody who has it mounted on the coldside and ask them why the did that because i dont even know why its done that way..the benefit of atmospheric bov (venting) and not recirculating it is because you get the sound more so than you would recirculating it
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
i had mine mounted on the cold side to reduce the temperature of the air hitting the mafs element. it still died after less than a month. after killing two sensors, i went back to a draw through and havent had problems since. the only benefits i saw was being able to vent atmospherically instead of recirc. some say it has better throttle response, i didnt notice.
S13FASTBACKSR
srpowered240sx wrote:the only benefits i saw was being able to vent atmospherically instead of recirc. some say it has better throttle response, i didnt notice.
are you saying that some people say venting has better throttle response over recirculating? because i heard that recirculating has better throttle response over venting
srpowered240sx
no, im saying having the maf closer to the throttle body has been said to have better response. not sure on the recirc vs atmosphere.
S13FASTBACKSR
oh ok i see man sorry about that..ya i heard that recirculating will help with better throttle response and take about a third of a second off of your qm time..not much but you know
spider_slayer
Car: S14 240SX
S13 240SX
the best thing to do if you decide to ditch the mafs is to go maps.
if you have the mafs on the cold or hot side under a good deal of boost then the filament in the mafs won't give quite the same resistance from not cooling as much as if it were draw through.
most of the time when a set-up is on a blow though its i conjunction with a maps.
srpowered240sx
i was under the impression that a map set up (manifold absolute pressure) completely replaced a maf (mass air flow) set up. hence why you can vent atmospherically. are you sure??
S13FASTBACKSR wrote: and take about a third of a second off of your qm time..not much but you know
never heard that, wonder where you get the extra horses from??
turblu
Running a MAP sensor completely removes the MAF from your setup. Im seriously considering the Apexi Power FC map setup more and more by the day now...
SpeedRacer1
Car: 1990 240SX, G35
Another alternative is to get the now discontinued HKS VPC to convert get rid of the MAFS.
superDorifto
Car: 1997 Eclipse Spyder - AWD/5spd swap in progress
1995 Q45 - 5spd swap in progress
1984 200sx hatch(KA-t swap) - 355WHP
1991/1993/1995/1997 240s - Dead
1982 200sx hatch - fixed/scrapped
getting real tired of the silent treatment.....where are my wheels, and where is my money?!!!! If you were trying to be a stealthy thief you did NOT cover your tracks nearly as good as you think....Ive sent you numerous emails, and called you numerous times, I WILL keep harassing you on NICO, and anywhere else i can find you until i have some answers.....Ive metioned it numerous times in private, but now im going to yell it load and proud....what you are doing is a FELLONY...mandatory jail time, youve scammed me and numerous other members and it will catch up with you eventually....run and hide...
