Blow through mass set up
slyde_wayz
Car: 1992 nissan 240sx
Cant find any info on a blow through mass setup. Someone help me.
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
If you have a turbo, are you sure if the turbo isn't blown and oil is getting everywhere?
robbbby
Cut your intercooler pipe on the "cold" side and put your MAF inbetween. Most people say you need at least 6" of straight pipe before the MAF.
PapaSmurf2k3
Site Admin
Just do the easiest/best thing, and put it right before the throttle body. the only problem is you have to re-direct the wiring because it usually comes out by the driver's side and now you are moving it to the pass. side, its easy tho, i think all you have to do is cut the ziptie or tape or whatever it is that is holding the maf wiring to all the other wires, then re-tape what you cut, without the maf wiring.
