Blow through MAFS?
skillzilla
Here is a pic of an RB20 in a 280Z, owned by a guy in Atlanta. Check out the MAFS placement. I wanted to do this to finally give my atmospheric BOV the finger, but thought it wouldnt work for some quarky Nissan reason.
So I guess it works fine, anyone else running this setup?
skillzilla
Oh BTW, I have a Cefiro motor and no stock BOV, so mine is on the hotpipe. Guess this wouldnt be any good for R32 motors.
SeVa-S13
Car: '05 GTO 6spd
I've ran a blow-through on a KA and a FWD SR, and plan to on the next RB; works fine for me. Carl also did/does the same, except his MAFS was leaking like a mofo for a while.
skillzilla
Awesome, Imma have to get on this then. All I need is a sawzall and some couplers
Chaos the Xile
Car: 1974 Datsun 260Z
So the MAF connects to the cold side of the motor? I wanna try this to on my RB25 but I have a custom intake plenum, so I don't have to cross pipes.
krayton
i ran blow thru for quite awhile with the rb25
no problems
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
Most people run it on the hotside becuase if you stick it to close to the throttle body and BOV, the air that surges or rushed backwards goes back through the maf, and the ECU ****s a brick and your car does retarded things.
krayton
never really had a problem with that. i closed the stock bov location and moved it down near the intercooler.
so when i would let off throttle the air would rush back through my maf then to the bov.
few people told me i might have problems, but i never (ie my maf would explode under pressure)
the whole reason i did the blowthru was so i could open bov. which would require the air to come back and go through the maf.
Chaos the Xile
ok so heres my motor what would be the best way to set up a blow thru maf?
krayton
well why are u guys wanting to run blow thru??
i see your bov right near the tb. are u having problems with it?
if your bov is ok then leave it on the hotside. a problem with blowthru is making lil brackets to hold it in place. but the only real reason i see going blowthru is to take care of the open bov
Carl H
Chaos the Xile wrote:ok so heres my motor what would be the best way to set up a blow thru maf?
fix the spahgegtti intercooler piping and redo it while plumbing the maf on the coldside of the intercooler.
i run a blowthru maf on my car mainly to stabilize the cam idle as well as reversion problems i could have with the large turbo.its not neccisary but it does allow you to vent your bov to atmosphere, big whoop.
Chaos the Xile
Carl H wrote:fix the spahgegtti intercooler piping and redo it while plumbing the maf on the coldside of the intercooler.
I was going to do that soon fixing that piping was first on my list, now on the coldside how far/close to the Intercooler should it be? And where do you have your BOV at Carl? Hot or Cold side? Pics would help I'm more of a visual person that auditory.
Carl H
idealy you should have the maf atleast 8" away from the throttle body to prevent reversion thru the maf when the tb closes, so usualy it ends up being in the passenger front gaurd area under the battery tray.you put the bov on the hotside so it wont interfere with the maf reading, it wont vent air quite as quickly as if it were on the coldside but it will still work.
krayton
Chaos the Xile
krayton wrote:found my old threads
zerothread?id=112020
zerothread?id=117594
Thanks for the Research For those links man. Hey what type of turbo mainfold was in that pic?
Shocker
Car: 89 240sxHB rb26/30
is that tin foil.. o.O
krayton
lol heat wrap.
track runnning in the summer desert heat was boiling my engine bay.
and those were all manifold adapters that i was playing with.
Shocker
i dont know, i didnt think they sould heat wrap at the local grocer... lol ive never seen heat wrap like that before, normally its the cloth type deal... lol
300Plus
Car: 1995 S14 w/ Rb25det Series II
I havent completely tested mine yet but seems good for me, my maf is on the coldside about....8 inch from the TB and the BOV is on the hotside a12 inchs before the intercooler and seems to be perfect so far.oh and make sure the air hose that feeds the IAC valve is after the maf or it wont idle correctly if at all
here a before clean up pic
