Blow through MAF
Sil240
Car: Nissan S13 "The One Cam Wonder"
If someone made one of these make the Nissan MAF work, it'd be nice.I know the KA guys used to cut up there MAF and put it into a same Diameter size piece of PVC and glue it together.
http://www.atpturbo.com/Mercha...e=BCS
Shocker
Car: 89 240sxHB rb26/30
looks like how an STI maf is setup.. makes it crazy easy to run a blow through, insures no leaks.
300Plus
Car: 1995 S14 w/ Rb25det Series II
Im running the stocker with epoxy around the electronics. but a buddy of mine in the Z world showed me an alluminum z32 MAF you just swap over the electronics. that would probably work if I find a pic or link I'll post it
here we go a pic and link to the thread:
http://www.sr20forum.com/showt...using
Modified by 300Plus at 8:27 AM 3/14/2007
fast_s14
Car: 94 300zx
i searched, found and conquered! Has anyone tried one of these housings? I have been searching for something like this for awhile hopefully the guy still has these for sale.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
the problem with that venture was, its not just unbolt and bolt on to the new housing. The electrical work had to be done as well to have to transferred.
there were other complications i believed. I spotted that as well back in the day.
Carl was the one that gave ear to some of those problems, hopefully he'll chime in...
gawdzilla
Car: none
you can't unbolt the sensor from the MAF like on other cars (lightning, sti, etc). requires you to cut out the electronics and either glue or weld into a new aluminum housing of your choice. this means good chance of messing up your MAF, or makes it a pita when your MAF eventually breaks. they all seem to break eventually
craz4240
Car: 1995 240sx w/rb20det
gawdzilla wrote:you can't unbolt the sensor from the MAF like on other cars (lightning, sti, etc). requires you to cut out the electronics and either glue or weld into a new aluminum housing of your choice. this means good chance of messing up your MAF, or makes it a pita when your MAF eventually breaks. they all seem to break eventually
Yep indeed I have had a couple nissan mafs apart and to even get the plug recepticle off the mafs you have to break the soldered joints.
fast_s14
Car: 94 300zx
i started taking a broken one apart and i stopped at where the plug is solderid to the pc board. After you desolder the plug does the rest of the pcboard and sensor just pull out?
BoostFab
Car: S13cp, S13fb, S14z
Sil240 wrote:If someone made one of these make the Nissan MAF work, it'd be nice.I know the KA guys used to cut up there MAF and put it into a same Diameter size piece of PVC and glue it together.
i had post that for someone on here a long time ago that were asking about blow through setup. you can use it w/ an sti maf sensor and use a safc to control the hotwire signals.
fast_s14
Car: 94 300zx
how much hp can the sti maf support and can u tune it with the PFC?
Carl H
once you desolder the connector you have to remove 3 screws holding the pcb down.if you DO take apart the maf that far there is actualy an oring seal...a little grey gasket rtv around that seal and then the sensor pcb remounted works. then if you reseal the maf plug and top using grey gasket and proper prep work you will never have another pressure issue.blowthru maf works but can be a pain in the ***...but it is nice when an ic pipe blows and you can atleast drive to the gas station.
jdmpurest
Car: 240SX
All the blow through maf setups I've seen just used an N62 with one of those aluminum adaptor pieces you bolt onto it.
WhatsADSM
Car: 1998 240sx
I ran a blow through MAF on my old RB20. It was a 2.5" MAF in blow through. It was the MAF from the LT1 trans am/camaro.... tried and true. I believe it supported somewhere around the 400-500whp range.
And if you wanted more the 3.5" Corvette MAF had the same connector and would flow enough to blow up just about any RB. (I believe people have made over 800whp on it).
jdmpurest
Car: 240SX
WhatsADSM wrote:I ran a blow through MAF on my old RB20. It was a 2.5" MAF in blow through. It was the MAF from the LT1 trans am/camaro.... tried and true. I believe it supported somewhere around the 400-500whp range.
Ford cobra mafs are good too.
WhatsADSM
Car: 1998 240sx
jdmpurest wrote:Ford cobra mafs are good too.
True story
Yea in fact I think the cobra MAFs have a native analog (0-5v output), whereas for the GM MAFs I listed above I had to make a small converter CPU and scale the output accordingly for the Nissan 0-5v hotwire.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
I'm going to be running the Lighting MAF blow through. Got a nice lil adapter to weld to my cold pipe. Anyone rem how far from throttle body the maf has to be? or dose it matter for the blow through maf setup?
fast_s14
Car: 94 300zx
i think i read some where on here that your supose to mount i 12 inches or so away from the throttle body. Can somone confirm this?
Bwana
Car: Denali
Mine *might* be 12" from the t/b but definitely not more and I've had 0 problems with it.
Sil240
I've heard from Supra guys that the MAF has to be at least 7" away with a straight behind it.
But i don't really know.
ripracer
Car: 01 Dodge Ram & 91 s13 hatch
Does anyone have pictures of running a blow through maf on a RB. I had Carl tune mine for blow-thru and planned to run right abot the valve cover but it looks like the MAF is too big.
Will probably put it on the coldpipe coming up through the fender.
Carryl
here my blow through setup.. no problems with it.... running 740cc injectors. tomei cams.. rb20 ....carl h tune
Yellow4g63
Hey what intakemanifold is that? got any pics of your cold pipe from it to the intercooler? I can't really see it too good.
Sil240
Yeah I can't really see either.
It looks like there is no ITM no, butt the water neck is there though....
jt15833
Car: 95' 240SX
does this help with the reliability issue of blow job MAFs?Is there any knowledge that some MAF's (such as cobra) will survive better as a blow job MAF?
RBSilvia
Car: '89 RB25 S13 Coupe
'91 SR20 S13 Coupe
lol lol lol
blow through, not blow job
Yellow4g63
RBSilvia wrote:lol lol lol
LoL I didn't cath that one lol
Carryl
hey its an rb26 intake manifold....itbs removed ...ill snap some pics of the cold pipe in a few
Bwana
Car: Denali
Pretty much how mine looks except the bends are tighter in my setup.
