rjyentsch21 »
https://forums.nicoclub.com/rjyentsch21-u66044.html
Fri Jan 11, 2008 11:09 am
So after I rebuilt the engine I had the motor set up with the MAF (stock) on a pull through setup. I got it to idle, but it was rough and would ?miss? a bit more than it should. When trying to rev the engine or drive it, it would be very rough from about idle to around 2000 rpm, then it would smooth out. Coming off the throttle would also cause it to try to stall. These symptoms seemed to point to either a problem with the BOV (which I did have recirculating) and/or the MAF being in pull through. So yesterday I reconfigured everything so that I now have a blow through MAF on the cold side and an open BOV in the hot side IC piping...except for one problem: I can't get the dang thing to start now.
She'll turn over fine and occasionally cough like she's trying, but overall she is pretty quiet and just won't catch. Pulling the plugs I find that they are wet, but not fouled. I didn't mess with anything else (except for plugging one manifold vacuum that I had forgot during the engine rebuild and left open).
Obviously I seem to have created issues with the MAF. It tried to put it with about six inches of relatively strait pipe before the sensor itself, and yes, it is pointed in the right direction. Does the ECU even reference the MAF when trying to start? Should I try starting with the MAF unplugged? Is the tune for a pull through MAF SIGNIFICANTLY different from the tune for a blow through MAF? Also, is there any initial adjustment for the idle screw that I could have messed up when I plugged that leak? Would that make a difference when starting?
Full stats below, pictures can be taken if necessary.
Rebuilt engine w/ 8.5:1 compression, forged rods, new gaskets, bearings, all clearances checked, etc. etc. Compression is where it should be on an unbroken in engine.Enthalpy tuned ECU (16 bit daughter board)50 lb. fuel injectors255 lph fuel pumpadjustable FPR (currently set to the stock ~43 psi)tubular manifoldT3/T04E turbocharger2.5" open downpipenarrowband O2 sensor and gaugeboost gaugeoil pressure guageaftermarket temp gaugeblow through stock MAF on the cold sideBlow off valve on the hot side (open)wastegaterelocated batterynew clutchone stage colder than stock plugs gapped to .035MSD coiland nothing else that I can really think off being important right now...
