Blow though setup
Charlie240sxt
Car: 95 240sx SE Ka24det!!! 98 audi A4
I am taking the 240 under the knife(its about time) want a blow though setup how do i do this the RIGHT way its going on the cold side how far from the TB? any tips?? 300zx MAF
Florida240sx
Anywhere....
ppctx
Car: 93 ka24de-t
Is there any negative in running a blow thru setup. I've read that it can damage the MAF, is that true/how true? it seems that blow thru would give more accurate intake air temp readings? Are there any benefits to running suck thru?
neverlift
IMHO blow thru owns. you can vta without stumbble or that over rich backfire. now black smoke when you lift. faster warm ups(from my experience). much better at metering the intake air not the pre compressed air.
best spot in my book is just before the TB.
Florida240sx
Just make sure you have a back up mafs in your car. In case it goes bad. Same can happen for pre-turbo as well.
