Projex240 wrote:blow through is the shizzle--open atmosphere BOV's, and its supposedly more accurate because it actually reads the motors intake rather than whats being sucked through the turbo. IM all for Blow through.
The MAF will read the same amount of air regardless of where it is located. In a blowthrough set-up, the air is denser, but slower. In a Draw-through set up, the air is faster, but not as dense. The actual mass of air does not change for a given boost, load and RPM. If any differences in accuracy exists, it wioll not be so much in the volume of air, but rather the time it takes for the measure volume of air to actually enter the motor.
