bersh240 wrote:the guy is an ex gm engine developer guy and is an expert in tuning and has the whole in shop floor dyno and all that good stuff. hes a good tuner. but speacilizes in drag cars and such and hasnt worked with a ca in years. and since the thread told me to recirculate it it just worries me that it isnt. basically the answer im looking for is why does the CA18det need to have a recirulated bov? and will it harm my engine if it isnt?
wWth any mass air flow metered engine you need to recirculate the bov if the maf is before the turbo i.e. "draw through" as is the way they ca and all stock turbo maf cars are, the pressure loss when venting the bov that is after the maf causes the engine to stumble because of the pressure loss from the bov opening.
If you are running a "blow through" maf setup, you can place the bov before the maf and vent it, as there is no pressure loss after the maf. Likely you will not be running a blow through setup as it requires a lot of tuning changes for little benefit on a mostly stock setup.
If you are looking for a setup that runs and idles like stock, I suggest making it as "stock" as possible in terms of its layout. Draw through maf (maf before the turbo) and recirculate the bov (after the maf, before the turbo. between them)
This will ensure the proper readings on the maf, and wont cause your car to bog or stumble.
Also if your tuner says he wants you to do leg work to find out about your setup, he is eiher trying to teach you or has no idea what he is talking about, in any event i would highly suggest taking your car to someone who has a lot of and recent experience tuning ca18's. they arent like sbc, unfortunately.
