blow off valve vacume line
burnout 180
Car: 1990 s13 180sx ca18det
What is the purpose of connecting a vaccume line to a blow off valve?
because I installed a skyline blow off valve on my ca18det and when i connected the vaccume line to it opens up at idal which means that the blow off valve is allways open. So i'm losing pressure.
So i wanted to know if the blow off valve would work if i closed up the vaccum line and let the air pressure open it manually.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
burnout 180 wrote:What is the purpose of connecting a vaccume line to a blow off valve?
The pressure under boost helps keep it closed and the vacuum let's it open.
burnout 180
so blocking of the vaccum line to it would do more harm than good?
I thought that doing this would allow the pressure to manually open up the valve instead of the vaccum causing me to lose pressure
themadscientist
your blowoff valve would not respond properly. What type of BOV do you have?
