ashibah83 »
https://forums.nicoclub.com/ashibah83-u48930.html
Mon Mar 23, 2009 3:45 pm
on a low power setup like what your talking about doing, i would use a pull through setup
IMO you get better air flow metering with a blow through setup, ideally for big numbers you would go with a MAP sensor, delete the MAF, and go standalone, im not sure if the stock ECU can support a blow through setup, people normally switch to a z32 MAF or something larger when they go blowthrough, and i dont know if an Ethalpy tune can support it
