Blow Off Valve Problem
mikesr86
Car: AE86 Sr20det swap
Whats going on. Im new to this forum. Anyway, I have a sr20det redtop in my ae86. The blowoff valve that I have been using since I got this car has been a greddy type-s. The type-s for some reason constantly stays open which means that the spring is probably no good, right ? I can feel air coming out all of the time and it is always whistling when I am stopped. When I am driving normally it does not whistle. So I then decided to buy a Greddy type-rs valve since they do not make a rebuild kit for the type-s anymore. But when I install the type-rs valve my car shuts off all of the time. It only runs well with the leaking blowoff valve. Does anyone know why this could be happening ? I appreciate any info you can give. thanks
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
You didn't block off the IACV did you?
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
invest into a recirculating kit for those bovs and also disassemble the components and clean them then use anti sieze to coat the piston. Should stick alot less.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
I'd say just get the HKS SSQV.. It seems every person I see with a boosted Nissan and a Greddy BOV has to fight with it.
mikesr86
Nope...i did not block off the iacv...So the Hks ssqv gets good reviews on the sr20det?
PyR0NiAk
O, yes. And there are a LOT of people running them atmospheric without issues... (Maybe a tap of the throttle during decel, but that's minimal.)
mikesr86
cool...I will look into getting an hks ssqv...thanks
