I had mine on the cold side. I'm not too sure that it really makes a big difference which side it is on though. Not really sure what this has to do with RB's...Chaos the Xile wrote:Which side do you have blow off valve on? Hot or Cold? I have mine on the cold side. Lets see it post up pics of your blow off valve and which side you have it on!
Yet i still have a large amount of compressor surge on hotside...Kamin wrote:location dosent matter.
the pressure differential between sides of the IC has no bearing on that because there is a sudden, large, pressure increase when you close the throttle (how a BOV works.)
so does mine, but i have the stiffer blitz bov spring, flutters like 3 or 4 times when i shift.The adjustment screw is all the way loose.Yellow4g63 wrote: I had mine close the the Throttle body. Worked good for me, I had a little surge problem till I adjusted the bov.
Ok I didn't know if it mattered which side, thanks Kamin. I have a Greddy Type-S BOV and a GT35R turbo w/ V-Band. The screw that is on top of the BOV is spripped out, so I need to get another one, I may get TiAL 50mm or HKS SSQV, Don't Know yet, but I need to get it tuned so it stops dying at idle, and so i don't have to recirc my BOV...Kansei240sx wrote:I am going to use two of them becuase the cold side is quite alot shorter and has less pressure build up than the hotside which the piping is about 1 to 2 feet shorter. See the long blue pipe on the hotside?Thats where another one is going....
Spazz put back in the spring that came with it. I too had the stiffer one and and it would surge no matter how lose it was lol. I don't know if I'll need the stiffer spring with the SC61. I hope so that damn thing cost me $40 lol.Spazz wrote:so does mine, but i have the stiffer blitz bov spring, flutters like 3 or 4 times when i shift.The adjustment screw is all the way loose.
my stock bov couldnt catch 1.2 bar from my t3/t4 on the hotside. moved to coldside no problem.Kansei240sx wrote:Yet i still have a large amount of compressor surge on hotside...
Too much Chapelles show for you young man...Stop watching it I demand it!!!!BigPar wrote:I'm going to get a mitsu 1g HKS SSQV adaptor flange to put it in my stock location on the ballin *** intake manifold cross over pipe. Them I'm going to sprinkle diamonds on it, becuase that's straight BALLIN!
I've seen this too but I'd imagine you'd get some sort of leak from somewhere.projeks13 wrote:true, but i've seen ppl keep the stocker on the cold side while still placing an aftermarket on the hot side (all to my knowledge were on single turbo setups)
