rn240sx wrote:
I have the Tial 35mm and the top port has NEVER been hooked up to anything. Its always been vented. Even with my EBC, its still vented..
My ebc is hooked up IN-LINE between the compressor and the wastegate side port...
No problems so far
exactly. the purpose of the top nipple on the Tial wastegates is to ADD pressure as a form of raising boost instead of bleeding the pressure off like most people do. you can still choose that option (I'm using a Hallman MBC inline with the boost ID line) works fine for me
but in regard to the topic of this thread: try to tee off from a source on the intake plenum itself. I redid all my vacuum lines when I installed my kit and I chose to run one of the unused nipples off the upper intake plenum to the upper nipple on my Greddy type S, then I T'd off from my boost ID signal (directly ON my compressor housing on the turbo that goes to the wastegate) to the lower nipple on my BOV. You dont have to run the second line, its purpose is to maintain positive pressure in the lower portion of the BOV's chamber, making the action more crisp. the BOV will still work just fine without it. Think of it as pushing a block. when your throttle plate is open (on the gas) there is positive pressure on both sides of the chamber so you would be pushing on both sides of the block equally, thus keeping it in one place (closed) with the throttle plate closed (off of gas) there is a vaccum in the top chamber of the BOV. so you now have positive pressure in the bottom chamber pushing up on the BOV and negative pressure pulling on it.
hope that makes sense.
