you should do a compression test before coming to any conclusions about anything. this will tell you if your rings are bad, and how bad they are. do a compression test(wide open throttle, with coil plug off and fuel pump fuse out) and if you get low numbers add a small bit(a capfull of oil from an oil bottle) of oil to each cyl and retest it. if it raises the rings are worn and that calls for a rebuild since...:replacing your piston rings is a very intensive job for an amature mechanic. it would be cheaper/easier/less time consuming to replace the engine with another. the process would involve removing the engine, then removing the head, timing chain, crank, rods, pistons, etc. so basically you would be doing a full rebuild as it is not advised to reuse used bearings and such. so it could get costly, and its a very delicate job. if its not your main car have at it if you feel you can do it. if its your only car, buy another engine and swap it on the weekend.im not sure about your idle problem though.seksehowy wrote:A friend of mine said I'm getting a blow by in my cylinders, where the o-ring or something sealing the pistons are leaking and the oils getting into the ignition chamber onto the sparkplug. Is that why im getting oils on my sparkplugs? and if it is. how hard is it to fix that? replacing the oring and all. do i have to take out the intake manifold and timing chain and such? anyone had experience with this before? help plz
at the same time, i also have an idling problem where it wont idle when it is cold, rpm will drop and stall, but when the engine is warmed up it idles fine. could this be from the "blow by" oils leaking on the sparkplug?. I've installed a new iacv same problem.thanks for your time.
