Koshin »
https://forums.nicoclub.com/koshin-u89386.html
Tue Apr 28, 2009 11:52 am
....just because you have a catch can doesnt make it right
Only two things cause that kind of blow by...
1. weak oil rings
2. bad turbo seal
if your turbo is new, its probably your rings...not to be the guy with the bad news...just being real with you, when this started happening to my old SR, it was the rings....do a compression check and see what you come up with...you should be 155-160 accorss theb board...
Rich
