cdiver »
https://forums.nicoclub.com/cdiver-u4828.html
Fri Jan 02, 2004 10:13 pm
Hello to All!
I’ve searched the Form and I can’t find any posting on how to “un-block” the windshield washer sprayer. I know there is a blockage, because when I disconnect the lines and hit the on button water is pumped through the line; but when I connect the line back, all I get is a slow dribble out of one and none out of the other. Any ideas?
I’ve been thinking about disconnecting the main water supply line and blowing the down stream lines with compressed air. I don’t want to use a pin/sharp object to “clean” the spray nozzles, because I’m afraid of screwing up the nozzle spray pattern.
Thanks,
Stephen
