BLKTP S13 Engine Recipe????
BenjiD
Car: 89 S13 Coupe SR20 Mildly Built 2871R(GONE)
91 Hatch DD Wheels 5 Lug Brakes,Coilovers
S14 SE GTR Wheels Mostly Stock
Ok You guy's Here's what I'm Thinking w My SR Build.Tell me what you thinkFresh Head- BC Stage 2 Cams, Titaniaum Springs, Retainers, Multi Angle V Job, Solid Lifters Apexi Stock Thickness H GSKTSTD Bore 9-1 Forged pistons, Carillo Rods, ACL Race Bearings, H studs R bolts3076R w peakboost header, Tial 38mm W/G w 44MM BellPower FC Djetro, World elec B/C750 INJ. Greddy Intake w Q45 TBAny input would be grattly appreciated!!!!!!!!! Shottin For Good Spool Maybe 500 HP
gixxerbob
go with oversized CP pistons 86.5 or 87 so the cylinder walls are fresh, have the block bored,honed,tanked, decked, blah blah.... have the crank mic'd, poliched and rotating assy balanced, blah blah.... also consider the twin scroll full race gt3071r kit.i assume you mean eagle h-beam rods w/ arp bolts. also use arp main studs and have the mains line bored.
