float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Fri Apr 04, 2003 6:19 pm
I've never actually done it either, but a guy on here with a KA-T did it with his swap and he had a FM with an atmospheric BOV and it worked just fine for him. I don't like MAFS all together. I don't care where you put it, it's a restriction. Granted that it is probabally better to have it on the suction side of the turbo than the pressure side, as far as air flow is concerned, but if you want to fix you stumble for the price lengthening the wires, it's a pretty cheap way to do it and I don't really see you restrictin the air flow THAT much. Your computer would also be getting a much more accurate count of the air going into the motor as it would be adjusting for the dense cool air as apposed to the hot engine bay air. Maybe someone with experience can elighten us.....
