Blitz SS Bov
capowered240
Car: 90 240sx
I have the blitz SS bov and I was wanting to know can the spring ever get weak that it needs to be changed out. Is there anyway of getting a stiffer spring? Has anyone ever changed out the spring in the bov? The spring that I have in my bov seems kinda weak.
float_6969
If it's strong enough to make it not leak at idle, it should be fine. But in answer to your question, yes, I suppose it's possible to have it cycled enough times to weaken the spring, but it would have to be a VERY old BOV. I would think that a Blitz dealer could get you replacement springs.
capowered240
Car: 90 240sx
Alright, ya it does leak alittle at idle. I would like to replace it anyway so I know it's good. All it is is one big spring. I've got this one
Modified by capowered240 at 4:58 PM 12/11/2006
Modified by capowered240 at 12:10 PM 12/12/2006
themadscientist
use the screw at the top to stiffen it up, that's what it's for.
Ca20silvia
Car: 1990 Nissan silvia Ca20det
If you undo the C clip at the bottom of the plunger slide it out, its like a top hat inside, flip it over so it puts more tension on the spring.Lube up the pluger also.Mine used to leak but now it supports well over 18 PSI with no problems
capowered240
Car: 90 240sx
I'll try that then.
capowered240
Car: 90 240sx
Already did that.
