this is going to be my first real big upgrade, so any help will be greatly appreciated
yes sir that is possible. but finding it will be your issue, i tried to find it and i had no luck. but maybe i just searched in the wrong plACES. idk. you could maybe go to a muffler shop and have them do it. and just weld the cat on to the pipe. then that will solve the leak problem and also no bolts either. but you will have to cut the cat off again i believe since your sr swapping. or maybe the sr down pipe will bolt on the cat. idk. i never had a sr. or even looked at a sr downpipe installed.pierre240 wrote:is there any way i could replace the cat with piping that has 2.5in on one side and 3in on the other to make up for the gap?
