Pepperoni wrote:are you sure the new sound you get is supposed to sound like that and it's not actually compressor surge?
I've always had the chattering sound with or without recirculation when blowing off at lower boost . By recirculating the bov, the sound of higher boost blow offs has changed from Pschhhhhh to Pschh-ch-ch....
The only indication I had (with the atmospheric setup) of proper bov operation was loss of air or excessively rich condition --- by observing the car's tendency to stall on idle immediately following a "chattering" blow off.
If I was really experiencing compressor surge, that would mean that air was being forced back against the compressor blades right?-----which would mean that the bov was not opening up----which also means no loss of metered air --- hence no stallage. Therefore, if I was experiencing stallage with chattering blow offs, then I probably did not have compressor surge.
Do I have compressor surge? I sure hope not. I never adjusted the bov adjustment screw since I took the bov out of the factory box. If it wasn't surging before, I wouldn't think recirculating would make any difference----unless somebody can show me otherwise
