bawllz »
https://forums.nicoclub.com/bawllz-u128553.html
Mon Mar 30, 2009 7:42 pm
Hey guys,first post here! I drive a 240sr in alberta. Anyway I will cut to the chase. I have ran into some problems installing my turbo timer. I have all the wires hooked up, how ever when I start the car, the fatt turns on and gives me the voltage of my battery. I change the mode to auto timer, and as i drive the number changes as it should, when I drive harder number goes up... however, when I turn off my car, the timer stays on but the car just shuts off with nothing. For the timer to turn off i have to manualy turn it off.
I have checked my handbrake ground, and after it still didnt work I wired it to a constant ground. So it has to be the accessory, the ignition, or the 12v+. Also I want to confirm that it is pinout 32 on my ecu? Please help in any way you can!
its an 1990 s13.
