blitz ecu
driftitsideways
Car: surfing,drifting,rally
Hey guys i was wondering if any of you know how high the Blitz access ecu revs to and how much of a hp gain i might get from it?Ive got t28 turbo, boost is at 12psi ,intake, fmic, 3"downpipe/exhaust ,and ca16de cams. If any of you know anything about this ecu let me know what you think. Any suggestions would be awsome. Thanks alot guys!
chezina
I just read your post and i was wondering if u are still running the stock ECU (without hitting fuelcut?)? I don't know much about the BLITZ ECU (basically it's a standard ECu equipped with a daughterboard), the specs are depending on the chip u use.But i know for shure that the stock fuel system is only good for max. 270ps no matter what ECU or turbo u use, if u wanna go past 270ps u need to upgrade AFM and injectors.Click HERE for a dyno run t28 with stock fueling(except fuel pump) and HERE for t28 with bigger injectors and AFM. Hope this helps.
