Blitz ECU
kings88
Car: '89 S13 coupe
Hey all, i got a swap down on my S13. Came with a Blitz Access ECU. As far as I know, it took the rev limit off and did some fuel training. What else can i do with this ECU? How do I find out what it can support?
Ca_Silvia
That is the ****ty part about getting "pre tuned" ECUs is that you have no idea what they are actually tuned for.
Generally speaking most aftermarket ECUs are no boost cut, no fuel cut, and removed top speed and like you said some sort of fuel/ignition map.
themadscientist
unless there is a label that lists what it's tuned for it's too dangerous to use. The gas over here is higher octane too usually. Better contact Blitz and get the 411.
Blitz Performance Sales 17300 Railroad Street Unit B City of Industry, CA 91748 TEL +1-626-839-8350 FAX +1-626-839-8340 http://www.blitz-performance.com/ License R-FIT MEISTER
mbmbmb23
Take the cover off the ECU, if the chip isnt glued into the socket you can unplug it...mail it to me...and I'll put it in my eprom reader and see what its tuned for....then I'll mail it back.
