slw240sx »
https://forums.nicoclub.com/slw240sx-u528.html
Fri Sep 26, 2003 8:32 pm
yep i gots one, i like it a million times more then a manual makes the car way faster and smoother, but untill i know how to properly set it up and work with it, i cant comment on how good it really is since i think it could work a 100 times better then it does, it seems to not limit boost to a set point lets it run over alot ill set it to 10psi and ill see myself holding 13psi steady at WOT, but again i really havent played with it enough to know how to truely work it i have to really take some time one day and tune it. its speed boost feature looks like it will rock once i put it to use,
also i got the power meter ID with it , i dont know other then using it as a speedmeter since i have a JDM cluster i think its a waste of space
