Blinking over-drive light?
lofapoo
Car: Toyota sedan
Search didn't give me a damn thing, so I came here. Sometimes when I start my car the overdrive light blinks rapidly then the light stays solid when O/D is enabled. It doesn't often but I've noticed it a few times. Was just wondering if something else needs to be fixed or not, cause I love fixing broken things causing more things to break and needing replacement :p I thought I ran into a thread on this a little while back but I can't find it for the life of me. Anyone wanna share some input? Thanks
SeVa-S13
Car: '05 GTO 6spd
It's the "You need a manual transmission" light.
lofapoo
Car: Toyota sedan
Yes yes, thank you for rubbing in what I think every single ****ing time I look at my car.
I need a manual transmission.
SeVa-S13
Car: '05 GTO 6spd
Well i did some searching and apparently it means there's a fault with the TCM and you should pull codes. There's supposedly a thread in 240 Convertible that covers Auto transmission problems and explains how to pull codes...but I couldn't find it.
574-240sx
Car: Nissans, Toyotas, Subaru
something is wrong. My light use to go crazy because I converted to manual and eventually I took the light out.
JimmyMethod
Car: 97' 240SX SE
SeVa-S13 wrote:It's the "You need a manual transmission" light.
*classic*
Indyspazz
It's your car letting you know you're driving an autotragic.
lofapoo
Car: Toyota sedan
Wow, I've never heard that one before, how clever!
I think it's time for you to go back home http://www.honda-tech.com
Indyspazz
Wow man, thanks! I lost that link out of my bookmarks!
If you really wanna know what code's you're throwing, drive over to autozone and borrow one of their diagnostic tools. They let you use them for free... saved me alot of time when I swapped the DE into my 89.
lofapoo
Car: Toyota sedan
See, if you had said that in the first place, neither of us would have to make an *** out of ourselves.
Thanks, I'll check out any nearby Autozones, but I'm in fear of what I might find in the parking lot :p
