This is quoted from automotiveforums.com here is the link:Transmission code P0740
ISOKE9 wrote:When I start my car on my 2001 nissan maxima gle (AUTOMATIC TRANSMISION),
My overdrive lights flashes 16 times when i start the car, I checked the obd code, and is showing as TRANSMISSION SERVICE CODE P0740
DOES ANYONE KNOWN WHAT THIS MEANS?
nahkapohjola wrote:See FSM AT-page: AT-42
X P0740T/C clutch solenoid valve I ; TCM detects an improper voltagedrop when it tries to operate the solenoid valve.T/C CLUTCH SOL/V , TCC SOLENOID/
ISOKE9 wrote:My problem has been fixed.
thank you guys for all your help
After getting a diagnostic done at nissan, the problem appeared to have been a faulty solenoid.
I took it to a shop that a friend recommended and had the solenoid assembly replaced (shift solenoid valve)
The car now shifts much easier!Engine light gone.
