blinking "Air Bag" light
qdriver
OK, I'm stupid. On my 94 Q45, I pulled and replaced a few of the fusable links/solenoids under the hood while the key was turned on by accident. Also messed with a couple connections under the passenger side dash.Everything is OK now, except the air bag light blinks now. Is there a way to reset this?Gracias.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Just go through and check all the connections you messed with. All the airbag wires are marked yellow.
bfbass
Wow, thanks for the fast response.I rechecked all the connections for the yellow wires under the pass side dash, and they all are solid connections. Silly light keeps blinking though. Additional ideas?
Q45tech
The are 20 pages of info and test proceedures in your service manual to determine which of 10 circuits are defective.As long as it blinks the air bags are not working.
qdriver
Where can I get a shop manual?I checked at the local shops and nobody has one, or can even order one.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
CJQ45
Car: 1997 Q 77k 03 Maxima GLE 19k
Had the same problem with my Q. Heres what you gotta do:
1. Insert the key and turn all the way on WITOUT starting the car.
2. Do this while leaving the driver side door open.
3. Press and release the dome light switch at least 5 times rapidly.
4. Turn car off and remove key
Next time you turn it on it should be gone.Looks like you put the car into "test mode". This WILL NOT WORK if you were in a collision and there is something wrong with the airbag.
If you take it to a dealer- they'll charge you $50 to do the same thing described above.CJ
bfbass
Now thats what I needed. Thanks so much!!!!Worked great.
JEC
Car: Motorcycles, cars, physical fitness
Now for the real "idiot" question of the day: which switch are we talking about to operate the dome light? The same one that dims the dash lights by turning?
Thanks, and please pardon my ignorance!
jefftrexler
Car: 1991 Nissan Maxima
JEC wrote:Now for the real "idiot" question of the day: which switch are we talking about to operate the dome light? The same one that dims the dash lights by turning?
I too would like to know what "Dome light button" in which you are reffering! I've tried following whats in the repair manual, but its rather criptic. My air-bag light has been blinking for quite some time.
CJQ45
Glad it here it worked - Its a pain to see it blinking while driving!!
The dome light switch is the one located at the base of the driver side door. Its the switch that controls the interior light as you open the door.
Keep in mind it will NOT WORK if the car was in a collision or there is something really wrong with the airbag.CJ
jefftrexler
OHHH!!! You mean the driver's door pin switch. Well I just tried it and BOOYAH! It worked like a charm!!! Its so great to have that damned light not blinking anymore. Every time someone rides in the car with me they always warn me that the airbag light is blinking. Got annoying having to explain it over and over again. Thanks allot for the info CJQ45!!!!!!:ylsuper
CJQ45 wrote:Glad it here it worked - Its a pain to see it blinking while driving!!
szh
Car: 2018 Tesla Model 3.
While I am sure that the people with their air-bag lights on appreciate the info, I find it amazing that the methods described for this (and other simple things like re-programming key fobs) are so cryptic and obtuse and non-intuitive! I suppose you have to pick things that are not likely to be done in normal operation, but, really!
Wouldn't it have been easier to have a simple serial port jack somewhere in the car where you could plug in a computer keyboard or an old-style serial CRT terminal and do these kinds of things? Or is my computing background biasing me here? :confused:
Z
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
szhosain wrote:While I am sure that the people with their air-bag lights on appreciate the info, I find it amazing that the methods described for this (and other simple things like re-programming key fobs) are so cryptic and obtuse and non-intuitive! Z
Coder job security.
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
good fix i changed my battery last night now my cd changer works again but my air ag light blinks, called dealor this morning $65.00 10minutes no appointment necessary (toud them to f off)did the fix above added 1 step lock drivers door after procedure
all good
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
Wish I'd known that about 3 years ago... wound up unplugging the light when I replaced the cluster lens. Maybe I'm a fatalist after all.
