Blinkers won't work
GreenMonster
Car: Infiniti I30
My blinkers have been on the fritz for a while. Sometimes they will blink 4-5 times, sometimes it's 1-2 times, sometimes not at all. I bought from Napa a an Electronic Flasher (EP-34) which they said would fix the problem.However, it does not. I spoke with another Napa store and they confirmed that EP-34 was the correct Electronic Flasher to use for my car.
The new flasher has only three prongs/plugs on the end. The flasher that controls the turn signals (I checked to make sure I was removing the correct one) has four prongs/plugs.
Any advise as to what I'm doing wrong or if I have the incorrect part from Napa?
Thanks
maxhopper
Car: 02 Maxima SE 6spd
Welcome to NICO!
What year is your I30? I'll see what I can find in the factory service manual.
GreenMonster
Car: Infiniti I30
Thanks! My car is 1998. Any help you provide would be greatefuly appreciated.
maxhopper
I would take the flasher you removed up to NAPA and let them double check.
What happens when you put on your hazard lights? Does it matter which way you were signaling?
GreenMonster
Car: Infiniti I30
Not a bad idea...I'd have to return the old on anyway.
When I turn on my hazzards they behave the same way the turn signals do...somestimes they blink 3-4, sometimes 1-2 and sometimes not at all.
No, it doesn't matter which direction you put the turn signal. It behaves the same either way.
Thanks
maxhopper
At this point I'm sure this sounds dumb; but have you checked to make sure all your turn signal bulbs are functioning?
maxhopper
Here are copies of the wiring diagrams from the FSM.
And here is the diagnostic chart.
