Blinker Problemm!!!
Zell311
Car: s14 SE zenki
okay so ive found one thread on this and it did not give me clear answersi have a 95 s14 se
what is supposed to blink on the front of the car?also when i turn my blinker switch none of my blinkers blink on the whole car. including when i use the hazards? what could this be?
also the car make no motion to blink internally or externally
nismoracingsx
Car: 1993 White 240sx Coupe
sounds like your blinker relay and/or controller is bad. Download yourself a factory service manual and diagnose your electrical system..a few posters on here have links to the fsm's for our cars.
Zell311
Car: s14 SE zenki
exactly what i expected seeing that they are all located on the same switch... also the car doesnt have any blinkers so i guess i should be picking some up lol
bassboy3313
Car: 1991 240sx hatchback
i have the blinker problem where when i put my right signal on, it blinks faster than normal, but both the front and back ARE blinking. they are dim compared to normal, but they do blink. when i put my hazards on they blink normal speed but the right side is just dimmer than the left. left side is perfectly fine tho. any ideas?
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
Sounds like you have a ground problem.
Zell311
Car: s14 SE zenki
me or mass boy?
sx moneypit
1986 Toyota MR2
I was referring to Bassboy. Zell your problem sounds like the turn signal switch or flasher.
Zell311
Car: s14 SE zenki
yeah im buying a new turn signal swtich as we speak... but my hazard dont work either... do the hazrds run through the turn signal switch or are they on there own circuit?
sx moneypit
1986 Toyota MR2
They do share some of the same circuits.
