Summary/TLDR
In order of priority
Car won't start
Thought it was the starter this time, or the solenoid, because the battery is good (~12.44v) and jumpering the battery positive directly to the starter wire (B/Y) at the connector close to the starter yields no results; not even a click. I've tried jump-starting as well; no luck. This is the start wire with no key in the ignition:
[youtube]http://www.youtube.com/watch?v=UUporXHLAaU[/youtube]
This same wire shows 12v+ with key turned to start, but the car doesn't start. Took the starter and had it bench tested at Advance; it's GOOD (??). Battery too. Other starter post shows 12v+ at all times, as it should.
Turn signals/hazards
PROBLEM #1: Initially, the fuse would blow occasionally. I think I've narrowed that down to activating the right turn signal while applying the brake, but I haven't found where the problem is.
PROBLEM #2: Now, however, after putting back together the SMJ etc., I have some weird behavior in the circuit:
- Hazards only work in rear
- With hazards on, regardless of key position, activating right or left turn signal causes front right/left turn signals to flash (incorrect behavior; nothing should happen with key at OFF)
- With key at ON, only front turn signals work, but they flash quickly (indication of burnt out bulb usually)
EDIT: Looks like this one was just the SMJ not being screwed in tight enough.
Windshield wipers
They come on by themselves occasionally if I go over a bump (railroad tracks are a pretty sure bet) and then usually don't go off until I hit another bump. Intermittent problem, haven't been able to trace it but it might be related to the other electrical issues.
Alarm system
I have a CrimeGuard 745i (ancient) in the car that worked fine up until these issues started. Now I have to leave it disconnected because it behaves erratically.
Headlights stuck in raised position
I tried removing the H/L RET DOWN relay (under air filter) and jumpering the posts; this caused the headlights to go down, so the problem is somewhere upstream towards the switch. Visual inspection of the switch itself and immediate harness yields nothing; it seems fine. Haven't done a full voltmeter test yet.
Speakers
Left door speaker cuts out sometimes but can be triggered by turning volume up real loud for a second, or banging my fist on the door. Low priority; the right speaker blew out so I may have to replace both anyway, at which point I'll examine the wiring in the door.
Original post
Hope you like mysteries...
I have a number of sporadic electrical issues which I'm starting to think are related...on chronological order as best I remember from when they first started showing up:
- Windshield wiper starts on its own sometimes if I make a turn or go over a bump. sometimes it will stop again if I hit another bump, but otherwise I have to pull the fuse. Turning the car off and back on doesnt usually help, wiper picks up right where it left off. Switch works normally except there's no off in these cases, the "off" position results in slow or medium speed sweeping.
- Left door speakers cut out occasionally, can be fixed by banging on the inside of the door with my fist OR by turning the volume up until the speaker starts working, then turning it back down to normal levels (??? no idea why this works). note that i put in the whole audio system years ago, i'd think it was my fault if not for all these other issues. still possibly unrelated, just thought its worth mentioning.
- Headlights stuck in raised position. I cut the brown wire a long time ago so I can control their closing (for sleepy eyes), but they still worked fine for a long time. then they started sometimes not opening and i'd have to wiggle the switch to get them to come up. now they dont go DOWN, ever.
- Aftermarket alarm started behaving very strangely, going off by itself etc. I ended up disabling this for now until I have time to diagnose it, so I don't think it's directly related to the other problems.
- Turn signal fuse blows on right turns, but not while car stopped. Hazard fuse blows if i then turn them on as well. This is obviously the first really serious issue and started last month. I've replaced about a dozen fuses in that time, inspected every wire i could find in the dash, can't figure it out. Not the relay because I replaced the old 4x hyperflasher i had in there with the stock relay, and it didnt help. I can't get it to blow while the car is off (ACC or ON but engine not running), but as soon as I try a right turn signal while driving it blows (EDIT: Not always on the first blink. Sometimes it takes half a dozen blinks, sometimes it's immediate. Can't tell if it's related to the wheel turning or just time/chance).
THANK YOU for reading.
