BLINK CODE MIND BOGGLE 88 PATHFINDER
DANJINFLA
Car: 88 PATHFINDER XE 6
I'm working on a 88 Pathfinder V-6 AT. 4x4 and the blink codes are driving me NUTS! No other diagnostic ports found
Both yellow and Green are blinking (not supposed to happen both @ the same time)once fast twice fast3 slow4 slow5 slow
This is meaningless in any of the tech spec's I've read
The symptoms are 2600 RPM's it acts like it is hitting a REV Limiterbefore I through away abunch of money replacing this and that...Anybody have any Ideas
ANY AND ALL IDEAS WILL BE TRIED..THANKS DAN
nametakennow
Car: '06 MINI Cooper S
Sounds like some kind of safe mode. In order to get a proper diagnostic you're probably stuck going to a dealer.
ricebike
2002 Quest
2005 Altima
88pathoffroad
Car: 1988 Nissan Pathfinder XE V6
If it stalls at 2750 RPM's either your MAF sensor, TPS or injectors have something wrong with them. Your flashing ECU lights indicate the possible diagnostic modes your ECU can be used in. You want to flip the diagnostic switch the other direction when it flashes the lights 3 times. Then it will start flashing your error codes. That puts it in Mode 3, which displays the error codes. The LED's should be red and green, not yellow.
http://npora.ipbhost.com//index.php?showtopic=21
