Blind Spot Detection Sensor
Big_Tone
Car: 2011 Infiniti M56x (White w Java interior; Tech Pkg)
PPE Headers; HPS Intake
Custom 2 1/4” exhaust with Jones Exhaust X-Pipe
Infiniti Sport mufflers
My IBA Off light has been on awhile now. The dealership said the right side blind spot object module needed to be replaced, which is part # 24k0-1me4a. Looks like it’s in the rear bumper. Does anyone know if the bumper has to be removed to get to it, or is it through the trunk?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Your ride uses side radars located at the corners of the rear bumper. See DAS-425 and DAS-592 here:
https://www.nicoclub.com/service-manual ... %2FDAS.pdf
Note that the units aren't plug-and-play. They come from the factory deactivated and have to be turned on using work support software. I'm not sure if anything besides a dealer Consult3+ can do that.
Big_Tone
VStar650CL wrote:
Sun Feb 04, 2024 2:13 pm
Thanks for the info! I bought a used module. Not sure if that matters. Would I have to remove the bumper to replace it? Once it's in I could take it to the dealer if it has to be activated. It would be much cheaper than the $1800 the quoted for the new part & labor they quoted.
VStar650CL
Technical Expert
A used one should already be activated. I'm not sure on an M, but on most of them you can take one side of the bumper fascia loose and hang it on a bungee without removing the whole thing.
Big_Tone
VStar650CL wrote:
Sun Feb 04, 2024 2:45 pm
Perfect. Thanks!
VStar650CL
Technical Expert
:dblthumb:
Big_Tone
VStar650CL wrote:
Sun Feb 04, 2024 3:46 pm
:dblthumb:
I installed the new module today, but I'm still getting the same error. I wonder if it still has to be activated for my car even though it's used. I'm assuming there's no way I can reset the system myself, right?
VStar650CL
Technical Expert
Not that I know of. They don't specify what the "activation" is, so it occurs to me that it may be to arrange a handshake between the radar and the ADAS. If so, it would still be necessary even with a used one.
Big_Tone
VStar650CL wrote:
Wed Feb 07, 2024 1:57 pm
Makes sense.
David__Allen
Car: 2013 Infiniti M37x S - Current
2000 BMW 328i - SOLD
2004 Infiniti G35 Coupe - SOLD
2008 Lexus IS250 - SOLD
2003 Lexus IS300 - SOLD
FYI, I recently went through this as one of my blind spot sensors was damaged in a rear-end collision. I installed a used one from eBay and it works perfect.
Can probably be done without completely removing the bumper, but I had it off anyways.
