dekansnowman »
https://forums.nicoclub.com/dekansnowman-u39284.html
Sun Jul 27, 2008 8:51 am
Ok so I blew an S13 SR T25/28 hybrid drifting and figured I would quickly shut it down and trailer it back home. After spending a couple weeks deciding the fate of the CA I bought an S15 GT28R-4, (With the incanel fins, etc) and sent the car in for paint and got new hood.. I had it back at the shop and turned it back on to make sure what I thought the problem was is in fact right. I let it idle, sounded fine, except the scratching obviously coming from the turbo. Took the intake elbow off and you can easily move the shaft around like a 360 joystick. It was awesome. No point in revving because I don't want pieces of that junk going anywhere so about about 10 seconds of idle I kill it. Well, Friday night me and a good friend take on the task of removing old turbo and installing new turbo. Notice the size difference!
So 15 hours later, no rush mind you, and some good tunes we get everything on, sealed, checked, and double checked before we start motor to break in the turbo. Following the instructions from Garrett to a T we spend 7 mins idling the turbo and checking for any leaks, and flow of oil and coolant. Everything checks out great and we are ready to take it out for a short, low speed cruise. Well, we start it up again and check fluid levels and then give it a slight increase in throttle.. Damn, I notice rod knock. WTF..... Now it only happens during a rev, and sounds perfect on idle. Can bearings be a "simple" fix? Please help me get this newly dolled up car back on the road.
