blew rear hub please help
nd_aussie
Car: 1994 300zx 2+2 bout to be tt&1987 rx7 s5 turbo II
ok so yesterday i went to the tire store to get new tires. they jacked the car up and went to start with the rear. as they were trying to take the wheel off the wheel had play in it. They had told me it was the wheel bearing that was blown and i would need to replace it or my wheel would fall off. So honestly im scared now to drive anywhere but i need to know where to get the hub assembly, how hard it is to change. Also when i look online it comes up with a part number 512014 which they say is called the hub bearing assembly and its 130$ but when i call a autoparts store they tell me is 512377. I need this asap. also would anyone reccommend a used hub? off a parts car.
ProudNissanFreak
Car: 2005 Imaginary WRX STi, 2003 Civic
Call a local dealership to get the exact part number first.
Here's a thread regarding it:
rear-wheel-bearing-t87141.html?hilit=512014
The 512014 is "the bearing only, to get the hub pressed in."
nd_aussie
should i replace hub to or just bearing?
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Cheaper to just get the bearing and press it in if you're doing the work yourself, but if you're taking it to a shop, do whatever they say is cheaper. It'll be the same mechanical outcome either way.
es.biggs
Car: 1990 300ZX 5sp NA
LOL your wheel isn't going to fall off.
Usually it's fine just to replace the bearing, unless the bearing had completely failed and damaged the hub
andrewbueno92
Car: 90 Nissan 300zx 2 seater manual slick-top.
i think your the one that traded for my hubs and spindles. yeah they were a b**** to uninstall. tell me how fun it is to install them.
