blew my engine.. need info on how to fix it without geting a new engine
Komatsu X
Car: Silvia
hey i was on the freeway doing about 50 and my rad cracked in all my water came out and i didnt know. well anyway my car overheated and it started to slow down.. i just turned the engine off when i was still going on the freeway then i pulled over and towed it home. when i tryed to start it it just sound like the starter was turning the engine with out the head being on the engine.. so i took the plugs out and i had water in the frist 3 cylinders . and i did a compresstion test and i got between 35 - 40 on cylinders 1-5 and on cylinder and cylinder 6 i got 100. and i dont know what do it . what do you think i should do? someone told me that i should just replace the head gas it and it should fix all my problems is this true? becuase i didnt think so but im not sure
Tictakman
sounds like the headgasket if its around the same numbers on a couple of the cylinders. basically ur gonna have to change the hg. hopfully no further damage happened like a warped head or messed up pistons. since ur changing the hg u might want to pull ur pistons and check and see how the rings and such look. good luck man
Z
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Pull the head for sure and check the condition of the head gasket. It seems to be blown but for all cylinders? That is weird to me so I would guess it's more of a problem with your rings being fried. Just to be on the safe side, I would take out the cams, bring the head to a shop and have them resurface it. It's cheap insurance for the new head gasket that you will install while you're in there.
DustinZ
Car: 1990 Z32, rb25 s13, 1980 S130 10th anniversary, 1978 5speed fact ac s30, s2 rb26 on deck!
Take the head off, send it to the machine shop and have it checked and resurfaced. Even though most people say you don't have to check the deck on an iron block I would. You lifted the head off of the block. You will deffinately need new head bolts so maybe think arp. Good luck!!!
300Plus
Car: 1995 S14 w/ Rb25det Series II
DustinZ wrote:Take the head off, send it to the machine shop and have it checked and resurfaced. Even though most people say you don't have to check the deck on an iron block I would. You lifted the head off of the block. You will deffinately need new head bolts so maybe think arp. Good luck!!!
I agree. Sounds like a lifted head or extremely warped Keep us posted!
Joe
winnar.
there is no easy fix in this situation. replacment engine or rebuild is gonna cost the same amount...
Komatsu X
Car: Silvia
heres some pics tell me what you think?
Komatsu X
Car: Silvia
heres one
Komatsu X
Car: Silvia
onemore
Komatsu X
Car: Silvia
sorry i dont know how to post them all and one post. this is the last one let me know what you think?
Joe
i think your ****ed
you need to have a machine shop inspect the block. but a mising piece of piston usually = block destroied.
240slidekat
Car: 240sx, 280z, gsxr1000, m3
wow that doesnt look good but if you need a headgasket i have a spare (brand new) one. 55 bucks shipped and its yours.
Darius
hahahaha are you serious?! you have a head gasket for him?! nice.
I'm sorry man but those pics make it look like your cylinders are out of round and melted at the top. Or maybe that's just the head gasket fried in two spots. I'd bring it to a shop for inspection, but I'd also start looking for a new motor.
Komatsu X
Car: Silvia
sorry i just got all the gaskets for a rubuild yesterday for free thanks anyway..
Carl H
hg is still on the block so it makes it look more effed up than it is, also the coolant/oil on the pistons will distort it and the rb20 pistons are flattop from the factory with reliefs for the valves...
Komatsu X
Car: Silvia
hey i took some pics after i tryed to clean it up alittle..
Shahee1
Car: 1993 240sx w RB20DET
Put the motor back together and try it out ... the gasket looked a little war-torn but your pistons look fine just in need of a little cleaning.
Joe
Shahee1 wrote:Put the motor back together and try it out ... the gasket looked a little war-torn but your pistons look fine just in need of a little cleaning.
im pretty sure #2 is missing a piece.
Darius
Do you have better pics or more closeup ones showing the tops of each cylinder? Also, if you blew your head gasket I would STRONGLY encourage you to have your head resurfaced. It's very cheap insurance. ~$40
Swedish Mike
Car: Golf TDI, Volvo 850T5 and 200sx S13 Hatch
Looks like detonations helped you blow it. It often melt gaskets and pistons.Measure the block and check the head for damage. Resurface like they say.
And when you´re done, check the AFR and EGT.
/Mike
Shocker
Car: 89 240sxHB rb26/30
yea #2 definitally looks like it has a chip outta it.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
I think he is selling his blown motor swap and prob getting another motor. I saw a post made by him on Zilvia in the forsale section.
Komatsu X
Car: Silvia
NAW I GOT IT RUNING IM NOT SELLING IT ANYMORE..LOL
IT WAS THE WIRING
IM JUST GOING TO PAINT MY CAR AND PUT IT UP FOR SALE AND USE THE MONEY TO GET A AE86
Stealth-Z
Car: 1991 300ZX
Komatsu X wrote:NAW I GOT IT RUNING IM NOT SELLING IT ANYMORE..LOL
IT WAS THE WIRING
zerothread/179514http://cgi.ebay.com/ebaymotors...QrdZ1
Komatsu X
Car: Silvia
yea i have 3 engine sets... so if you need two of anything let me know
Yellow4g63
IT WAS THE WIRING
There is a place in Ontairo that has 4 4AGE 20valve Silver tops for $450 each. No engine harness tho but still a slaming deal.
Komatsu X
Car: Silvia
hey hey hey do u got the number ?? email anything ill pick one up right now?
