zerepdivad »
https://forums.nicoclub.com/zerepdivad-u34747.html
Tue Oct 21, 2008 7:57 pm
Ok a bit of a background....set upz32 mafsdw 440cc injectorsemance tunenismo adj fprt3aem uegosafc1etcstcok internalsWas running a ka-t on an emance tune for about 4 months and 5000 miles or so. Always had a problem of running rich in boost with it but i squared that away with my safc. But recently i overheated and blew my headgasket so i figured i have a spare ka in the garage that it'd be easier to just swap it out. Which it was that took a lot less than it woudl have took me to swap out a head gasket and get the head checked etc....So i swap in my motor and keep in mind its basically the same as my old oen except this oen has all the emissions removed, unlike my old one which just had the egr pipe cut and welded shut and the lines to the charcoal canister plugged. Only hting i did to this motor was re do the intake manifold gaskets, and reseal the front timing cover, and did the timing chains.
So here's the problem.... I start up the car starts like normal but has an unusually high idle around 2 grand and fluctuates a bit. Revs smoothly for the first minute or so, then letting it idle for a bit it starts to miss and my wideband reads like 10 at idle! Then from there my idle is crappy and it won't rev because of the plugs getting fouled out so badly. And as the idle gets worse and the plugs get more fouled my vacuum goes down to like 10. from the 15-18 where it starts out at when it's running smooth once i throw in new plugs.
This whole thing is pretty strange seeing as how it's the EXACT same setup that i had with the old motor and it's giving me all this crap. This is leading em to believe possibley one of the the sensors on this motor is bad? But which one would cause a problem such as this? coolatn temp sensor? 02 sensor? etc...
I'm kind of stumped and am tired of buying new plugs for this slut.If anyone has any ideas be sure to let me knowany and all help is appreciated.
