Blew a rod, what did this to the piston?
tiger
Hey I was just curious what caused these markings on the piston, bought a 500 dollar lx 240 with a knock and tried to hump it home but blew a rod out the side and i just removed the head and discovered these markings on the piston
wa-chiss
Car: 1990 Nissan S13 H/C KA24E
2005 Toyota Sequoia
1976 Honda CB750F Super Sport
ats a new one on me.........
mrzabala
Car: 93 Nissan 240SX SE Hatch
Looks like that piston hit the the valves. Could be the the timing was off and the chain jumped a tooth(s). Over revving, oil starvation just some things that could cause it. Check underneath your your cylinder head where the valves seat.
tiger
hey, yeah that's what another friend suggested...that it hit valves... here is a picture of the underside of the head.
valves all look normal.. none look bent but i dont have the tools to remove the valves.. :/
mrzabala
Bring a light into the valve spring and see i you can see the valve rod. Only way you can have those markings on those pistons is the valve striking as I see the circular half's on opposite sides of the piston. Leaning towards over revving and or over heating/lubrication if the connecting rod shot out the side of the engine block.
tiger
I have been inspecting the valve surfaces on #3 and they look untouched and are all seated properly.. they do not hang open at all. I'm trying to make sure this head is O.K. to sell to someone. I will try looking for the valve rod to see any damage. I'll let you know. Thank you.
yellowcar
Could be from the piston dropping down too far in the cylinder when the rod went
tiger
hey that could be something cause I know it couldn't have touched the valves because there is no evidence of piston an valve contact.
wa-chiss
2005 Toyota Sequoia
^ true, I would bet it's not from the valves kissin the piston cause there's only 2 marks on the piston but yet you have 4 valves. There would be 4 markings if they hit. <-- yeah I know............ we todd did math.
tiger
i found out that it was from ouching the underside of the head, yhere eare those half moon markings...
wa-chiss
2005 Toyota Sequoia
Why didn't I think a dat.
Crichton
Car: 1991 Nissan 240Sx
no 100% sure but it looks like the top of the pison met the bottomof the head. But as I said not 100% sure. AN the only reason I sugest that is because. I am currently in the middle of the Cyl head rebuild an have notice that. The head as 2 spots that are like a ledge. an from the pic thats what it looks like to me. So maybe a streched rod?
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
To check the valve seats in the head poor gas down the ports. If they leak there bent if they stay dry there good.
tiger
that's what I figured.. I looked at the bottom of the head and saw that.. are you rebuilding the one i sold to Tam?
devil_child
bottom bearing slipped leaving a roughly 1mm room of play causing the piston to hit the flat quenches on the sides of the chamber.
tiger
ah, that makes perfect sense.. I was looking at a bearing and one had actually melted into the connecting rod.
Crichton
dude sorry to hear that!!!! Hope you have some luck finding a new long block. Give a shout if i can help ya out.
tiger
oh and if anyone needs a block, I have an extra
